gsxeclipse102
- 558
- 126
- Mar 8, 2003
carmel,
New York
Omg 15 degrees knock retard. Your lucky you didnt throw a rod through the block. You need to log raw knock count. It was prob like 40 counts.
What I can't figure out is, spark plugs are perfect, Pistons are spotless.... I'm getting weird knock like low rpm, light throttle. I think if this was all real knock my engine would of been damaged a lot worse then it was. The head gasket had no signs of burning. nothing!Omg 15 degrees knock retard. Your lucky you didnt throw a rod through the block. You need to log raw knock count. It was prob like 40 counts.
Car is back boys.....running great. Changed the thermostat and im running 200....doesnt move a muscle. Hitting 30lbs but lowered the timing, car rips!12:1 is lean on meth? Ok
You know what man, I don't see raw knock in the list when I check. I dropped the timing across the board to 16 degrees. Still a tiny bit of knock retard. This is at 32 psi so, I'm going to keep lowering the timing until all knock is gone and go from there. I'm almost totaled my car last night . Missed two f***ing deer by a foot. Would of destroyed my intercooler for sure. Also, I think my higher than normal temps were caused by air in the system because of the thermostat. Now my temp don't move at all.Very nice. Post up a log when you got a chance. No more knock i hope. Also remember to log raw knock count.
Headgasket #2 gone... pushing coolant. Done for the season boys. This motor does not like boost past 30 psi...... she did amazing at 27 with loads of timing spraying meth. The minute I increase boost past 30 I always run in to trouble. Motor never ran lean, plugs are perfect.... just think the surfaces need machining for that much boost. Block is ready for assembly. I'm going to pull the motor wed!If you go to captured items there should be a raw value section in the middle(i believe thats right). Remember knock retard is like 1 degree for 4 counts or something. Anything above .4 you need to watch. Air deff causes many problems in the cooling system. Did you go with a mls gasket or composite?
I dont think its a cracked cylinder, the shortblock looked immaculate, pistons were spotless. The car isnt even overheating or smoking, The head looks suspicious to me, I will find out soon enough. I ordered everything i need for the new motor. I will be running wiseco hd pistons with manley turbo tuff rods with all oem timing, oil and cooling partsAre you sure there Is not a cracked cylinder wall?
