Nate355RS
- 446
- 52
- Oct 25, 2012
Salem,
Virginia
Phrasing
I meant what I said , I'm gunna pound her out early so I can go work on the carPhrasing
Hey guys, heads off.... what do you guys think about the exhaust valves.... white? Intake valves look fineHow's the HG replacement coming along? Did u decide to keep the standard ARP's or not?
Head and block were flat, Put a straightYou need a straight edge. After popping a gasket like that both the head and block may need milled.
It's was a straight edge, not a machinist straight edge. I used a razor blade at a 90 and acetone to get the block as clean and residue free as I could. I have a motor I'm building that's sitting at Raif's shop, I'm waiting for him to get back from wcf. The block and head looked great actually. Honestly 100% of the time, I would of taken the head and block for machining. This is just a case of if it's fixed fine, if Not I'm pulling the motor for the winter. It's just 60 bucks. I have a brand new head I could of used, but I'm saving it for the new motor. I'm going to be finishing her up Monday. I can't see how a composite wouldn't seal, esp with studs. The new motor will be running a mls for sure.ill keep you postedHow flat was it? Was it a real machinists straight edge? How did you clean off the old gasket material?
When replacing a blown headgasket 99% of the time the head needs resurfaced. Most of these blocks that haven't been resurfaced in 25 years are at least .002" out.
I feel the same way. It helps with stress. I get so focused that I even forget to eat sometimes!You guys are gunna think I'm nuts. I find it relaxing working on my car.... so it doesn't bother me. Only time in my life when time stands still and I'm not thinking about all the bullshit going on...
holy shit, well there are many factors. Your not running factory compression yes? Its amazing how much power you pick up with a little more compression. I was running 34psi on the fp black with a fair amount of timing.....still think 5th gear got me. Never had one problem until 5th gear. Im gunna post my log so you guys can see exactly when it happened. If i was watching the check engine light I would of been ok. Id light to wire another light into that signal wire and mount it higher in my cabinOur setup was all new and freshly machined. We made it an entire week of racing at the salt flats on a composite head gasket over 800hp.
Oh yes, I dropped my peak timing to 16I dont think the 34 psi popped your headgasket. The insanely high timing (26 degrees i believe it was) prob killed it. Did you ever find out if your base timing was off?
holy sh**, well there are many factors. Your not running factory compression yes? Its amazing how much power you pick up with a little more compression. I was running 34psi on the fp black with a fair amount of timing.....still think 5th gear got me. Never had one problem until 5th gear. Im gunna post my log so you guys can see exactly when it happened. If i was watching the check engine light I would of been ok. Id light to wire another light into that signal wire and mount it higher in my cabin
The s wire is hooked up to a distriution block off the + on the battery, were i have my fuel pump etc. Its strange that the dsm link is reading low but when i check with the voltmeter at the battery i get 14.1Thats strange. My saturn alternator is always between 13.5 and 14. Did you hook up the s wire on the alternator? Its the sensing voltage wire.
Yah I got yah, this is a learning experience for me, I'm pretty confident without the meth injection the gasket/motor would have been gone awhile ago. If the motor is happy with the headgasket I'm going to lower my timing significantly and get on the dyno see what I can do. Still can't say enough about these motors, I don't care how primitive and inefficient they are. They just keep on giving.That car only runs 8.5:1. I do everything I can to talk people out of high static compression. It has no place on a forced induction car.
You need to get it out of your head that 18* timing is okay. If your base timing is at 5* then you have 23* total going into the motor. If you have it at 10* base then that is 28* total timing. You have to add your base timing into the situation ever time. Most cars I play with end up in the 14-18* total timing area. Make your power with your turbocharger, not your ignition. High cylinder pressure is the devil.
As what has been said, high load and high timing as well as high load and low rpm will ruin your day every time. Your head studs are not the problem, your tune it.
This is when is wentBe thankful you have made it this far. Not a lot of folks have the same luck. A little research will go a long way. Knowledge and experience will get you to the next level.
