Pirrofab
- 726
- 40
- Sep 2, 2006
gouldsboro,
Pennsylvania
I'm in quite a perdicament at the moment with turbo selection for a 2.3 stroker. I need to keep it stock appearing and keep cost down. I also want to keep it a mitsu flanged turbo and internally gated. Street manners are also in mind. This will be daily driven so reliability is also a factor.
Turbos I have thought of are
Evo3 16g- Fully ported
18g 6sl2- fully ported
SBR bastard 20g with tdo6 wheel also fully ported
T04B V-Trim ( Haven't heard much luck but its bolt on and semi stock appearing and SBR has one heck of a deal on them)
I know the airflow of a 2.3 really puts a strain on these turbos at the 6-7500 rpm range but I know someone has had to have tried this and would have some knowledge behind making it work. I've seen countless 2.0 16 g powered cars make it it into the 11's so I figured why not do it with a 2.3l. Stock appearing means everything to me on this build so if I have to scrap the 2.3 liter idea for a built 2.0 then I'll go that route but I really like the idea of a stroker.
. . . Or run low enough boost so that you only see the 48lb/min by redline. 22-23psi (2.5PR) and 2.4L of displacement assuming 90% VE will flow 0.32m^3/sec of volume flow at 7100rpms. 0.32m^2/sec is on the choke line of the 20g compressor. You will reach your goal with the 20g compressor, 400-450whp. You don't need .32m^/sec volume flow to reach this goal. Since you don't need .32m^3/sec volume flow to reach your horsepower goal, the 18g can still reach your goal or you can run even lower boost. Low boost means less heat (regardless of efficiency) and this would be good for pumpgas. I suggest the td06 20g.
, I'm going to build a evo/sti hunter. Its gonna be sleeper except for the intake and exhaust manifold.
