AntmanAndLittleDi
- 161
- 15
- Nov 12, 2014
Russell,
Kansas
I have been fighting what I thought was a auto trans problem for 6 months until today. After several phone calls I finally found a guy with a scanner to read the TCU. He couldn't access the TCU or PCM, but could manually access the ECU and turn accessories on/off. The whole time he would constantly get a message saying No DTC's present. Does this mean I need to flash my ECU? The ECU is the standard black box from the factory.
I do have extra mods done to the car: 16g turbo, BBK throttle body, 6" cone aircleaner, high volume fuel pump, and a few others. At this rate should I just buy a new ECU and software? Or will the stock ECU still work? I'm a wrench monkey, but this electronic stuff is still a little mumbo-jumbo yet. Trying to learn one thing at a time, but need electronics to work in order to keep wrenching
Any help is greatly appreciated. As an extra note: the car does run (beautifully), wideband is a little high (14.7) but hasn't ever been calibrated, and the only codes are for the catalytic converter (which is removed) and for the fuel pressure regulator (aftermarket installed). There are no leaks of any kind, anywhere. Just ask if you need more information. Thanks again for looking
.Any help is greatly appreciated. As an extra note: the car does run (beautifully), wideband is a little high (14.7) but hasn't ever been calibrated, and the only codes are for the catalytic converter (which is removed) and for the fuel pressure regulator (aftermarket installed). There are no leaks of any kind, anywhere. Just ask if you need more information. Thanks again for looking
