Still not sure i understand
bcjjones
509
6
Nov 3, 2011
Austin, Texas
About to install a SAFC 2 in my 1992 eagle talon tsi. I've found a few writeups on the 2g install put nothing on the 1g install. I did find one for the galant vr4 which im assuming is the same as my car?
But what im really curious about is if i completely cut the wires from the stock harness and only solder on the wires to the Safc? Therefore completely over riding the ECU with the SAFC, or do I basically just splice the wire and also leave it connected to the stock harnes?
Also probably not a very intelligent question, but I do plug the harness back into the ECU once everything is hooked up correct?
The SAFC basically intercepts the signal before it gets to the ecu, modifies it, and returns the modified version of the info to the ecu hence why you need to cut the MAF wire and put the SAFC in series to that wire. You will thus need to hook the ecu harness back in as the signal still needs to be sent to the ecu.
go to Visual Frequently Answered Questions - Home Page
then click on "Electrical", then
"Apexi S-AFC install for GVR4s and 1Gs"
Just double checking. My common sense told me that but its not always the best thing to go off of!
Sorry but that link didnt work for me, took me to a pic of a busted headlight
Thanks Lurker, thats the link i've been looking for. Found it a few days ago but couldnt find it again.
And thanks for the explination also. Makes sense
