2G starting issue grinds when I crank it
reyg
68
Dec 31, 2008
va beach, Virginia
So when I go to start my car I never have a problem getting it started however it sounds like really bad gear grinding. It does take a few times to get my car started and every time I crank it there is that grinding noise. Sometimes in between that 5 mins it sounds like a normal car cranking like the gears are in perfect mesh. Any thoughts?
post a video "car making grinding noise" isn't enough to go on, I could tell you it's starter grind and be completely wrong :p
Does your car have a 6-bolt swap or original 7-bolt?
Could be a bad starter plate, so the starter is out of alignment.
Check that.
7bolt. I will post a vid as soon as I can.
Don't exactly know how to check that.
