1cleangsx
- 1,821
- 2,483
- Sep 28, 2013
Cheyenne,
Wyoming
What do you guys run for tq on your cars? So far I’m having success on a dsm82, 32 psi, with a composite head gasket and standard arp’s torqued to 115 ft/lbs. E85 fuel with fat afr’s, 11.7-11.8, conservative timing, 14 degrees up top, the purpose of this thread is to hear about others success/failures with these standard studs vs cylinder pressure and high boost, my car hauls ass, but I’m proceeding with caution from this point on
Thanks!
with OEM gasket and slightly higher compression than stock (what that figure is I don't know). Right now it is probably a bit overkill for my stock turbo setup, but I have a Holset HX35 setup waiting around for me to finish getting the supporting mods in order. I am hoping to put down around 400 whp with boost hitting around the 35 psi mark, but in the end it will be up to what English Racing can do on the dyno... safely.
So obviously I backed it off for the sake of my stock bottom end, something to keep in mind
