2G ARP headstud question
97GSXmitsy
54
Apr 1, 2002
where ever, New Jersey
my car has a rebuilt motor in it with zero miles on it. has not left the drive way yet. it has only idled for a few mins here and there. when i finaly put it on the road, do i have to retorque the arp headstuds? when do i do this after a certain amount of miles or just cruise it around the block and then retorque them.? do i do it when the motor is still hot or wait for it to cool?
Run it through the first heatcycle, change the oil and what not then let the car completely cool down over night, then re-torque the studs when cold. :thumb:
Joe
SBR
so wait, let me understand this better.... you're saying change the oil after the first time of warming up and cooling down?
On a brand new engine, yes. Run it through a heat cycle for liek 20 minutes. Its the most critical part to breaking in an engine. After that heatcycle immediately change oil and filter. The filter is going to be contaminatd with assembly lube, metal shavings from rings and bearings seating and the oil will have some debris in it as well. Change all that before the car ever sees the road, then change the oil in 500mile intervals until about 2k and you should be good.
Joe
SBR
Word, I will give that a try. I'm using a single weight non detergent motor oil for my break in.... I was told to do this because it would glaze everything and cause the sealing of piston rings to be better off in the long run.
You can, i always use el cheapo 20w-50 but straight weight oil will work fine.
Joe
SBR
ive yet to drive the car but i have started the car about three times since rebuild. and i was having ecu problems and the car was reving to like 4 grand upon initial start up. ive fixed the problem and now the car idles beautifully at 900 rpm. think everything will be ok?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
