SS feed and return fuel line
DSM4LIFE-AWD
322
10
Aug 6, 2009
Trois-Rivieres, QC, Canada
I've been searching for 2 hours now and I only found 2 pictures of what I want to see ... :(
I just want to know how you place your ss line under the car. Did you used screw or pop rivet to fix the clamp that hold the ss line ? A picture would be nice and make my day ! :D
i used screws and when i ran it i put it next to the stock fuel and brake lines just to avoid having to move the new fuel lines to get to the brake lines incase they need repair...i dont have a picture right now but i can take 1 in a couple hours when i go to the car
So did you put the screw right in the floor or you placed the hose in the same place as the picture but not behind the brake line ... Got what I'm trying to say ... ?
Im interested too! I am going to be doing all new fuel lines this winter.. How did you tap the SS line into the fuel sending unit, or connect it to the old line coming out of the sending unit?
All I did was unbolt the bolt for the stock line holder, and slid those exact holders in there. Exactly like that guy did.
I just used zip ties and ran the lines along with the OEM ones. for the fuel sending unit...i pulled it out...cut off the stupid metal one that always breaks and made the hole bigger the accept the SS ones and i JB welded a 90 degree -6an fitting on there and ss line from the pump to that fitting ;)
