Spyder Power Antenna
epreski7
66
Aug 17, 2014
Oviedo, Florida
How can I disconnect the power going to the antenna. I bought the car with the antenna broken off so whenever I turn the car on or off it makes this annoying buzzing noise for like a minute. Is there any fuse I can take out to disconnect the power going to the antenna motor I looked in the inside fuse box and couldn't find anything
pull out your stereo and there is a big black plug, unplug it then you won't hear the annoying noise again. hope this helps.
I disconnected mine from within the trunk, you will have to remove the trim. in return I bought an power antenna block that mounts inside the panel that way there is no external antennas on the car. reception is not the greatest but does the job for now. when I paint the car I going to mount a shark fin with AM/FM, GPS and XM on the trunk lid right behind the spoiler.
