2G Spun 2 rod bearing at the dyno
Jacolu3
638
131
Jan 31, 2015
Lake Grove, New York
So I took my car to the dyno yesterday and after a few pulls we started to notice a ticking noise. So we decided to pull the car off the dyno and I had the car towed home. I dropped the oil pan today and found cylinder 1&4 have a spun rod bearing. I'm not sure what would have caused this to happen and now I'm not sure how to proceed.
The engine was built about 6000k miles ago with acl bearing with eagle rods and wiesco pistons.
Do I need to do a complete tear down now? Or can I just replace the bearings?
Complete tear down and polishing of the areas. May have to cut the crank and use over-sized bearings, etc. I would also check the rods for any heat indications showing a weak point. (Blueing, etc)
Someone either didn't know how to tune or they didn't know how to use Plastigauge.
Or "didnt know how to use torque wrench", thanks Kryndon. :)
Ouch, sorry about that man. Almost nothing worse than spinning bearings. Depending on how long the engine was ran after the failure, there would be a lot of contamination in the oil galleries and up top in the head. Definitely have to tear it all down for inspection and cleaning. I'd take a wild guess and say the rod caps were not properly torqued when assembling the engine.
Like 'livedsm4g63' has said, crank will have to me machined depending on how deep the scratches are and you'll need oversized bearings. Good luck!
Was the balance shafts eliminated on this motor? and if so was it the oem kit or ebay special... I have seen a few spun rod examples happen from using a knock off bse kits.
The balance shafts were eliminated. As for which kit, I'm not sure. I bought the motor with the bse already done so I never even touched it.
Yeah I was leaning towards the feeling of a complete tear down. I guess this is why if you want something done right you have to do it yourself.
On a possibly separate note, I pulled the plugs, which were brand new, installed once I got to the dyno, looked kind of rusted. Possible head gasket?
I fail to see how the damage is tune related
High counts of knock can cause bearing failures. Look at the top most bearing. If it looks beaten, you my good sir have detention. Looking at these, both sides look rather bad. All depends on when you catch the issue. It could have been knocking like crazy for the past x amount of miles and it finally gave away. Hard to say.
Also.... that tensioner shaft position LOL.
Depends how far the material got.
I would take off the feed/return line to see if you can find any debris.
Were you feeding from the head or from the ofh?
If there was a filter before the turbo, typically a rebuild isnt necessary.
First things first, time to rip out the powerplant, cleaned it up and check dimensions. Measuring other rod clearances may tell the story.
In the process now of pulling the motor.
I am feeding from the oil filter housing so I guess technically there is a filter before.
