Sullbren17
- 173
- 0
- Nov 29, 2012
Chadron,
Nebraska
If you bore your cylinders do you have to buy a special head gasket to match the size of the cylinders and with arp studs do I need a thicker head gasket or anything?
I would buy a Gasket that matches your bore size. OEM is fine or you can upgrade to a different brad.
I'm gussing the motor is out of the car. So flip it over remove oil pan and unbolt the mains, rods, and give it a little tap with a mallet and it should come free.
Post some pictures so people can help you more.
According to the Fel-pro Master Catalog
HG Part number 9627PT has a bore size of 3.405
STD 4g bore is 3.346 + .030 = 3.376
