For Sale SPECIAL DSMTUNERS TUNING OFFER INSIDE WITH PURCHASE!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
This offer is only being posted on the DSM Classifieds group and DSMTuners forums - These 2 sites in particular support me and my shop more than any others so I'm returning the favor!
PLEASE click LIKE that keeps the post visible!
DONT SEE IT? ASK! - I have the second largest DSM Parts inventory in the country!
RIX Racing - We are located in Morgantown WV - Willing to ship - and will deliver anything for Free to the shootout!
I also offer remote tuning and local dyno tuning here on my AWD Mustang Chassis Dyno in Morgantown WV.
Purchase over $500 and get 50% off a tune... Purchase over $1000 and comes with a free standard tuning session!
This offer will remain good until the Shootout and applies to either remote OR dyno tuning!!
DSM Stuff
Inspected/refreshed Magnus 4 Speed Dog Box - This will take at least 2 weeks to ship as it is still at an independent transmission shop being looked over - $4500
QM 6 bolt awd Twin Disc clutch with 1" splines for the aforementioned dog box - $600
Rebuilt Fuellab Prodigy fuel pump $424
88K mile super rare lime green color Stocky stock VERY rust free(Nevada car) 95 Talon TSI FWD Automatic - $4500
Black Sparktech "Drag" COP DSM ignition - Pro-12 M&W CDI - $850
Purple Sparktech "Drag" COP DSM Ignition - Pro-12 M&W CDI - $900
Brand new BSFab 3" vband downpipe with New clamps and flange - $450
Comp Turbos Billet 6765 T3 Turbocharger - $750
FIC "EasyTune" Box - $325
Healthy used 7 bolt long block - 850
Healthy used 6 bolt long block - 850
Good 2g AWD 5 speed Transmission - $700
Good 2g FWD 5 speed Transmission - $350
Good 2g LSD Manual Rear diff - $225
Good 91-96 23 spline T-case - $150
90-96 manual half shaft with carrier bearing - $75
Good 92k mile 1g 22 spline manual trans - $350
Good 92k mile 1g 22 spline tcase - $150
Built 6 bolt shortblock - $2400
3000 miles very healthy
complete deck down
Eagle Crank
Scat Rods
Manley Pistons
MHI Pump
complete deck down inspected
Built 6 bolt Shortblock - $1500
OEM Crank
Ross 8.5:1 Pistons
Eagle rods
MHI Pump
BSE Delete
complete deck down
healthy pull - inspected
refreshed Built 6 bolt shortblock $1750
Eagle rods
wiseco pistons
MHI Pump
timing belt broke so there are some marks in the pistons from valve contact that we cleaned up and reinstalled
new acl bearings
new rings and fresh hone
cleaned and inspected
Ported and Polished 2g head - Crower springs and retainers SS Valves - $425
healthy clean 1g head - Supertech dual springs and retainers - $500
GSC S3 Cams (Has also been drilled to accomodate a 2gb CAS if necessary) - $425
Turbonetic style cast t3 exhaust manifold - $100
Cleaned and serviced ID 725 HI-Z injectors - $350
Cleaned and Serviced FIC 775 HI-z Injectors - $325
Cleaned and Serviced PTE 1200 Low-Z Injectors - $295
Cleaned and Serviced Bosch 1450 HI-Z Injectors - $425
Uncracked valve cover with -10 an fittings tapped on the top(sleeves welded in) - No baffles - $100
Skunk 2 Super lightweight Adjustable cam gears (Silver) - $130
2g non cruise cable - $35
1g non cruse cable - $35
2g non abs lines and prop valve - $85
1g non abs lines adn propvalve - $85
Accufab 75mm Throttle body - $150
S90 Throttle body with sensors and ISC - $175
SBR/HAFE Exhaust manifold flanged for 38mm 2 bolt wastegate - $225
A1 H11 Head studs for 7 bolt - $185
ARP 625 ARP Head Studs for 7 bolt - $310
ARP Standard 6 bolt head studs - $50
3g no-tick lifters - $65
2g Tokiko Illumina Adjustable Struts with Tokiko Red springs - $400
Good used Gates or Greddy Kevlar Timing belt - $45
2g Head - Recent deck still measures flat - Crower springs/retainers, SS Valves, 3 angle valve job - $475
Oil filter relocation kit - 100% filtration - $75
Aeromotive AFPR - $125
17" Rotas - No curb rash - $400
Freshly serviced Genuine EVO 3 Big 16g - $500
Fluidyne 2g Radiator - $200
Vibrant spark plug cover - $45
Shaved Valve cover painted black with -10 an fittings welded on Lines and catch can - $250
FP Intake with couplers - $100
Mishimoto fan shroud with fans - $75
Home made COP setup works with 1g or 2g (May need to switch 2 pins depending on yoru config) - $150
Mitsubishi(with the diamond star) badged VC no cracks - $125
BBK 62mm Throttle Body - $150
AEM Wideband - $125
LC1 Wideband - $130
EVO Stuff
I have 2 EVO Parts chassis's available with good panels and parts if you need bumpers or fenders or doors etc one is very low mileage at 49K but no title.. need something ASK!
SORRY I dont have ANY good headlights!
Cleaned asd Serviced FIC 1000 Low-Z injectors - $285
Cleaned and Serviced PTE 1000 Low-Z Injectors - $285
2 bolt F38 Tial wastegate - $125
STM Drag Brakes(Fresh rotors) - $850
Torque Solutions motor mounts - $325
AMS VSR Intake Manifold - $475
Boomba Throttle body - $350
Magnus SMIM - $400
Wilson TB (matches the above Magnus) - $150
evo 8/9 SS Upper intercooler pipe 2.5" mandrel bends Tial flanged - $140
Buschur double pumper for evo 8/9 w/ 2 255s - $400
Genuine Stanley EVO 7 Tail lights - $600
Blox front rollstop - $75
AEM Wideband - $125
EVO Fenders $200 a piece
EVO Doors - $200 a piece
OEM EVO 8 Tail lights - $150
Tarmac black EVO 8 front bumper in OK Shape- $200
RR Hood has baseball sized dent in nose very repairable - $250
EVO 8 Engine harness - 225
VERY GOOD Blue cloth seats from a 49K mile chassis - $500
49K mile EVO 8 Rear diff - $650
49K EVO 8 5 speed Transmission - $1200
49K EVO 8/9 Rear axles - $350
I have 2 built EVO 5 speed transmissions here - Bushwacker Stage 2 with Stock ratios and a Shep with stock ratios - I still need to pull them apart and inspect them as I have not seen them r - Less than un with my own eyes but I expect they are healthy - $2250 each
Complete Forward Facing Turbo setup - $3150
Sheepy FF Manifold
VBand .82 PTE 6766 DBB
Vband Turbosmart wastegate.
Feed Line
Return Line
Hood exit exhaust
hood exit wastegate tube
Half sized Mishimoto Radiator
Lower Intercooler pipe
Built EVO 9 shortblock - ~3000 miles on the build very healthy- $4850
Wiseco HD 10.5:1 pistons
Manley Rods
ARP Main studs
TRI Metal bearings
New MHI Oil pump
Still installed in the car will make video before I pull it!
EVO 9 GSC S2 Cams - $425
EVO 9 GSC S3 Cams - $425
EVO 8 HKS 264 Cams - $325
EVO 8 HKS 264/272 Cams - $325
I am positively missing things this is just a top of my head list!
