speakers
dsmman91
192
May 23, 2011
Tricites, Washington
what size speakers are in the back of a 91 plymouth laser rs by chance cause i dont want to pull apart the back of of my car just find out but if someone knows that would be awesome but if not o well
the12volt.com
common stereo wiring, speakers sizes, and alarm wiring and other misc information for tons of different makes and models.
Funny,
I've only seen 6x9" and 6.5" speakers in the rear of a 1G depending on which radio it came with. Are you guys sure about a non standard 6x8" speaker?
Since I'm not into pounding on the wheel well to make a large magnet 6x9" speaker fit I made a baffle plate to offset a standard 6.5". There's more room above the center line.
12volt say's rears are 6.5. they are usually pretty accurate.
They say the same about the Eclipse and that's not correct. CAPS lists two rear mounts one for 16cm speakers and one for 6x9" depending on the radio option.
they are shallow 6x9's, look for speakers with a small magnet. if it magnet makes contact with the framework you will have problems.
