Spark problem Eclipse Gs n/t
Tymon1986
Oct 5, 2011
Warsaw, Europe
Hi,
At the beginning there was no spark on two cylinders. Now there is no spark at any. When the engine working, check engine lights up. I was connected the computer to check ecu errors, there was an erro 44 ignition coils than swapped ignition coils and power transistor and still does not want to start (no spark). Ecu has the capacitors changed... What to do?:confused:
The new coil pack and PTU are known good units? Have you verified the ECU board and components are ok and damaged somewhere? Did you do any wire testing to ensure continuity from the PTU and coil pack to the ECU?
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
