Spark plugs don't fit
eclipsyco
607
27
Nov 19, 2011
Somewhere in, Central America
Hello!
This is my first post as you can see, this forum has helped me a lot but this time i didn't get any luck with the search option... the car is 95 gst and i bought new spark plugs for it (first time) i read that the ngk bpr6es is my best choise since i don't have any mods yet so i bought those but they don't fit :confused: they are too thick WTF ...
this is exactly what i got BPR6ES11 - NGK Spark Plug (4824) at www.carsparkplugs.com so what's up with this plugs???
Yeah take them back you need those with a 5/8 size hex, thats the skinny ones. Next time tell them what car you buyin them for so you will get the correct ones
You can use the smaller hex plugs but it's not necessary. I think you mean the spark plug wrench doesn't fit? Not all of them do if you're using a 13/16 socket which is what a bpr6es would required. bpr6es-11 would also require it. It's the wrong plug not because of size but because of the electrode and it's associated gap. that's a 4g63 NT plug. BPR6ES works just fine.
I am also looking to replace my plugs and I am looking to get the BPR6ES that everybody on here recommends, but when I do a model search on the NGK website those are not an option. Also when I am on the autozone website and have my make and model selected it says that part will not fit my car.
I get three plug options from the NGK website
NGK IX iridium 6637 BPR6EIX
NGK GP platinum 7084 BPR6EGP
NGK Multi-ground plug 6757 BPR6EKN
I have a 99 GST
I get the same when I use my year/model. I just search part numbers now (works on advancedauto's site, not sure about autozone) and order online to pickup in store. I believe the part numbers you need are either 4923 out 5534. They'll let you add to cart whether they fit your car or not, but will have a warning about them not being for your chosen vehicle.
I have a 99 GST
NGK's catalog recommends the BPR6EKN for our cars. But we're all rebels, so we use something different. ;) The 6ES is the same as the 6EKN except that it has a single electrode ground instead of a dual. And there's no real benefit to the double ground, and the 6ES plugs are cheaper and easier to come by, so that's what we use.
I use br7s. Simple, cheap and proven. Gapped at .028. That was on the t25 though LOL, the new 5858 i will prob gap down a few thousandths if necessary.
Oh, and whats the dif between BPR and BR?
LOL, i believe its spelled iridium. Im sure they work fine but theres no reason to use them. Copper is fine. Hell if you had the money, one of the best metals to possibly use would be tungsten or gold. But still, for a forced induction car, i think its pointless.
I know in my field of work(clinical engineering) all xray tubes anodes are tungsten. Very tough and dense metal that can disperse heat very quickly.
Guys there's one thing for sure that I learned from this threat is that every country or so have different names for the nkg spark plugs in us is BPR6ES or BR6ES I think. Here in Latin America the same plugs are called BCPR6ES in Europe is different as well but they are all the same that's why I was having a hard time finding them here.
I use BPR6EY - grooved electrode plugs. Keeps the spark round and doesn't get squished...puts out a nice bump too.
Thing about IR plugs is that the tip can get hotter being a lot smaller in diameter to really create the plasma spark ball.
True, tungsten is GREATstuff-hard as nails and super dense, but also gradually erodes from the high voltage sparks.
you'd be doing expensive plugs like you do oil changes.
The BPR6ES-11's are for the NT motors and gapped at .044.
Picked up my BPR6ES plugs today at Knecht's on sale for $1.50 each. Great buy. Cheapest maintenance I think I have ever done and with great results.
Make sure to gap them right and torque them right indeed cheapest, easiest maintenance FTW.
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
