2G Spark plug wires order and mbpr
jmonterful
55
Aug 25, 2015
grand island, Nebraska
Okay i've been doing research for about a week but i cant seem to find a good answer i have a 95 talon tsi and i just bought some ngk wires but i'm not sure if i'm putting them right. The coils are numbered 3-2-1-4 (right to left) do this numbers correspond to the numbers on the wires if so the dont seem to correspond because some seem too long and some too short i'm guiding out of a pic i found and i'll post down. Also i bought an ebay bpr while i get i better one just to turn down the boos a little and when i opened it the little ball came out and i'm not sure if it goes all the way to the bottom where the little spring goes or iit helps the screw turn i'm gonna do my best to draw it LOL hope u guys understand what i'm trying to say. Thanks for all the help!
I appreciate your response man. It was really late at night so i couldnt take any pics i'll show you what i'm talking about. Under the cooils it shows some numbers so i put the cables mayching those numbers but they dont seem like they belong there or unless i'm not putting them in the right spot on the cylinders. As i said in the pic it show the first one to be a "3" then goes 2-1-4 & aboit the bpr thats the only pic i cqn take unless i open it up i'm pretty sure the ball goes all the way to the bottom but when i opened it the ball came out almost instantly that is why i'm not sure i'm thinking the ball had to be on top to come out that quick. Hope that helps. Thanks alot!!
I don't see the problem. The wires look long because they aren't routed like stock. as far as where they plug in looks right.
Oh okay i just wanted to make sure because they dont look the same as the lenght of my old ones and look at #1 it has to go over the oil cap so it can reach thats why my question. Btw would it even matter if the cables are put on different spots or is the lenght change so they can reach the cylinder? Thanks
Obviously the number 1 isn't from that set.
For your boost controller the ball is supposed to be under the spring. It should go ball first, then the spring, and then the screw.
This bpr is a bleeder type from what i know. it has another "T" that has to go with it its different cause this one doesnt have a nipple across the screw it has it on the side. Thanks!
Yeah, without seeing the inside of the MBC I'm not really sure how it works. I found these pictures but they don't really show what is happening inside. From what I can tell that ball goes between the little spring and the set screw on the side. The bottom of the knob screw should be tapered and function as a needle valve regulating the boost bypass to the port without the arrow.
Just to add to the ignition wire situation. Remember that this is a waste-spark ignition system, so the order doesn't matter as long as you have cylinders 1-4 and 2-3 on the correct coil. So, you could swap 1 with 4 and 2 with 3 and you'd be fine.
Thanks man i wasnt able to find a pic like that LOL appreciate it:)
Just so i'm not confused is this set up right? So i can leave it like that. Thanks
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
