spark plug wire question
thewhiteone
74
Jan 26, 2011
Toledo, Ohio
so Im in the process of replacing the wires on my car to taylor 10.4mm wires, but with the tuck on my car, the shortest wire wont reach the coil pack.
my question is will it be okay to run an ngk 8mm while I wait for another wire to come in or should i just leave the four ngk in and put the taylor set in when I have four that will reach the coil pack?
thanks in advance
I would run the ones you have that will fit for now, and replace the ones you get once you get them. I guess im trying to figure out why the different ones would matter.
the ngks ark across the valve cover and i decided to upgrade to a larger wire.
is there any reason running two different sizes would affect the way the car runs?
I never ran different ones i guess if you install a different one youll know, i have used different wires but it didnt run any different, stock wires that is.
It might not be ideal, but I don't think you notice much difference, if any. And I sure don't think it will cause any problems from doing so. It's gotta be be better than having the arcing ones on there.:D
sounds good, Anything has to be better then arcing across the cover so i think ill put the massive taylors in and leave the baby ngk in until i can get a replacement for it.
thanks for the help, if anyone has any differing opinions let me know
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
