tc1155
- 0
- Sep 15, 2005
kenmore,
New York
Ok so I have spark on 1 and 4 using a spark tester. 2 and 3 get nothing. At the ignition module I have a signal making it there on both channel 1 and channel 2. So I know the ecu is working. The ignition module I have worked when the car drove in so I tested using the diy test with the test light and the battery and the light came on when it was suppost to and didn't when it suppost to. So I know the cas is sending the signal to the computer and in return the ecu is sending the signal to the ignition module. Now I replaced the ignition module with a new one and I still have the same issue. On a side note when I crank the motor over I also do not have a tach signal . Any help and input would be very helpful. I tried to twist the terminals on the ignition module alittle to make sure there is a good connection and still got nothing. Maybe i didn't twist them enough.
