someone give me a rough tune AFC2
n2orbit
298
May 10, 2003
friend is coming over tonight were going to install his afc2..
has a intake, uper ic pipes, t28 @ 18psi 2 1/2 downpipe and exhaust and a 255 fuel pump what should i put in for the base settings so we can tune it out
This link has a great guide for initial tuning and more advanced tuning.
http://www.racingknowledge.org/topic.asp?TOPIC_ID=1011
If you put your low throttle point at like 30% and the high at like 80% you should be good to start. Then go through the Ne points in the RPM range and space them out, and think about where you may need more adjustability (like where boost hits).
Definitely check out that first link and this one: http://www.roadraceengineering.com/newafcsetting.htm
Good luck and don't expect that you'll be right on the money at first. It will take a while to learn your car and what it likes.
_Craig
