Please Support Rix Racing
Please Support STM Tuned
Some traces of fluid in tie rod boots
n0c7
568
5
Jul 2, 2004
Edmonton, Alberta_Canada
Recently when I did my inner and outer tie rods, I found a trace amount of fluid(not very much) in one of the inner tie rod boots. I believe I have overfilled the power steering reservoir slightly. Does this indicate the seals could be blown or will too much fluid just leak out? The steering seems to work fine.
madtech707
32
Jun 1, 2006
Vallejo, California
The sign of p/s fluid in the boots means that the rack-n-pinoin seals are leaking and is not a normal condition. Rack-n-pinoin replacment would be needed. It seems like in your case of seeing a very small amount of fluid that your seals just may be starting to leak a little. I would not be too worried about it right now. Just keep an eye on your p/s fluid resevour level.
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned
