some questions about the bearings
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
bought a used block for a 100 bucks.It has all internals,alterntor,flywheel.oilpan,all the pulleys.The guy told me ,that the block is in good condition.well i wanted to put a BSEK ,and when i took off the oil pan,i saw some metal shavings in it.when i spun a rod bearing on my old block,it had a goldish metal flakes in the oil pan,but on this on i got lik silver color shavings.I checked the bearings,they all looked good.Should i go to the machine shop and give them to check everything again,or just leave as it is and put in the car???
well i took closer look,and it seems ,that some kind of aluminum part was broken.I found a lil peace of aluminum inside the oil pan.I took off the pistons,looked at them,but they all were good.So i don't know,maybe the guy that i bought the block,was doing something with head,and some little peaces went down the block to the oil pan......
well i just put the block into the car,changed the main oil seals,put a new oil and water pumps,new timing components,new clutch and flywheel.Tomorrow im gonna put the head on,do the timing and start my car up. I hope the block will not be trashed .....
