so i got a problem
viperfella
Jan 21, 2011
beulaville, North Carolina
i have an 1g eagle talon tsi fwd. so a couple days ago i was horsing around on it and wanted to see if it could burn the tires( i just got it a week ago). i poped the clutch at 4k and it spin and proceeded to pour smoke i thought i blew the motor, it turns out i blew the oil filter seal my question is what caused it to do this?
When you act like a dumbass your car is going to tell you that your being a dumbass by breaking, and your lucky it wasn't the motor. The oil filter seal was the weakest point in the setup and it blew, once you replace it and you start acting like a jackass again then the next thing that breaks will be the weakest. The rubber on the seal was probably old and rotted (stiff) so while you were mashing the gas your oil pressure increased. The increase in oil pressure found the weakest point of that seal and POP!
Maintenance before mods and before beating on your car. If somethings old, corroded, beat, destroyed, or just doesn't look right it needs to be replaced or at least monitored. That 1g is 20 years old so treat it like a 20 year old turbo car and take care of it...
:dsm:
yea i was an idiot and after this scare i plan to baby it and completely look the motor over. A couple of days before this happend i was coming back from school and as i jumped on the freeway my oil pressure gauge quit working could it possibly be a clog somewhere? or is it just because i was raping it
ah i see. after i saw that i didnt blow the motor it took me 4 hours to find where the leak was coming from. about 3 hours and 50 min of it was thinking about should i turn the motor over or shouldnt i
1 : The Oil pressure gauge is notorious for losing a good connection. Check the clip wire for play and make sure it's on the pressure sending unit firmly.
2 : You now own a turbo DSM. These vehicles are the most tempermental vehicles, likely, on the face of the planet. If you treat them right, they'll treat you right. if you abuse them and they don't like it (some of them are masochists) they'll certainly let you know.
You're lucky it was just that. It could have been a timing belt, a head gasket, the turbo, or a plethora of other things. When I got my first DSM i abused it from time to time, and each and every time it would act FINE... until I got it home. Once, I had a flywheel bolt back out and got it home. As soon as I clutched in my driveway to stop, the bolt caught the clutch plate, locked, and my engine died. It made sure I wasn't going ANYWHERE without dropping the transmission. Luckily no damage was done, just my own stupidity for not torquing with loctite.
Anywho, treat it right. Do the proper preventive work to it before you start trying to show off. Who knows? The next time you do that, your Transfer case may be like "Yeah, No Sir" and lock up.
i checked the wire and the clip is broken, and it was a purolator oil filter that was pretty new
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
