smoking brakes
gabriel_dsm
73
Mar 27, 2014
bakersfield, California
okay i have a 95 eclipse gs automatic! now when driving and i come to a stop i can smell smoke! when i get out at times its coming from the brakes in the back! sometimes also from what looks like the catalytic converter. my question is i thought the Gs was a FWD why is smoking from the back??
Don't gs models have drum in the rear? If it's drums it's a good idea to pop the drums off and check for a leaking wheel cylinder. You'll have to replace the shoes cause fluid will have ruined them. Get new hardware kit with all the springs. If they are calipers then it's probably seized.
It means one of your calipers are locked in position, due to a blockage in a line, an old caliper piston, a piece of debris, whatever is causing the brake not to release. Just stick a Jack under the suspicious wheel and see if you can turn it by hand
Yep, like SFgSx said. Jack up the rear end and give it a Price is Right spin to see if it can make a few rotations or if it stops in half a turn to narrow down which one is problem side.
You might be able to feel the heat on the wheel with your hand (preferably during a cold night). When the rear guide pins seized on both sides on my 3000gt, the wheels were warm/hot to the touch and the fronts were cold.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
