turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Well, i replaced the vavle seals when i built the motor, but not having any feel to when they are seated i think i may have damaged one or 3
(one actually looked crooked but it wouldn't go on any other way, i'm thinking it is too crooked, but i didn't mind at the time because replacing stem seals again would be far easier than everything else i had to get done at the time)
The car smokes at idle but it takes a minute to start then the longer it idles the worse it smokes, and it's not consistant at all. sometimes more sometimes less, but it has only recently started this.
Everything in the motor is rebuilt as most should know from my other threads on this, but just wanting to confirm or get some thoughts on this. Since it only happens at idle or under good vacum i am lead to believe it's the stem seals. I"m probably going to replace them tomorrow, but before i do i thought i'd get some input from you guys/gals. I"m mainly looking for install tips on how to know when they are peoperly seated without putting too much force on which would damage them (like my one that was crooked, it went that way because of a slight tap from a small hammer on install)
Anyone ever install the seals incorrectly or have issues like this on a fresh build? I've searched and read but most threads were never resolved.
(one actually looked crooked but it wouldn't go on any other way, i'm thinking it is too crooked, but i didn't mind at the time because replacing stem seals again would be far easier than everything else i had to get done at the time)The car smokes at idle but it takes a minute to start then the longer it idles the worse it smokes, and it's not consistant at all. sometimes more sometimes less, but it has only recently started this.
