darthvadar tsi
- 381
- 2
- Nov 9, 2010
Columbus,
Ohio
There is a little bit of smoke coming off of my exhaust manifold and it hasnt been droven a lot it sat for a few weeks also the weather is around 20 degrees. Do i have something to worry about or is it just those factors or something else? Thanks
Steve.
Steve.
If it continues to do it after driving it for a while you may have a problem.
If it's a crack you will surely see it coming right out when you start the car and you should hear some ticking type noise from the area. If not, you might see some oil running down from the valve cover around where the manifold bolts up to the head which is burning off. Or maybe you just had some condensation/moisture on the engine from having it sit in the cold garage, outside, or wherever you have it and there's nothing wrong with it.
