white smoke coming out of tail pipe
lazor55
Feb 11, 2010
cartersville, Georgia
just noticed last week that white smoke was coming out the tail pipe now its coming out all the time what you think the problem is
I am having the same issue in my car, but its only when I start it up and let it run for about 10mins or more. After I drive it, it doesnt do it anymore at until the next cold start.
I read the information about the possible causes of the white smoke. I changed my breather and my pcv valve and see how that works. I will get with you and let you know if that works or not.
That sounds like a blown head gasket. I would do a COLD compression test.
You know I have been noticing my Air/fuel ratio gauge has not being reading the mixture when I drive. I haven't seen the check engine light come on but I feel like my o2 sensors are going bad or bad,mainly because it's using a hell of a lot of gas now.
