Smart first order?
Bluedragondsm
350
Nov 14, 2002
Edmonton, AB, Canada
Have 100-150$ to spend and just bought a 100% stock tsi AWD. I am making an order some time this week and this is the order I am going for.
Goals for the car is stage 1 mods with a 16g and supporting fuel mods (this might change at some point)
1. Boost leak tester
2. New oil cap
3. Prosport mechanical Boost gauge
4. A pillar gauge pod
5. NXS MBC
That should about eat up my budget. Any other suggestions? I am making the order mostly from Mach V Motorsports - High Performance Car Parts if someone knows of a cheaper vendor let me know or any other suggestions for what I would need on a stock DSM.
Timing belt is being done at end of the month as well as new water pump and diff/trans fluid.
Go through the list of routine maintenence, and then do what you need to.
Usually I assume the prior owner did Nothing and do anything I can to bring the maintenance up to date. It seems expensive, but a timing belt job now is a lot cheaper than a complete head job later. (Though that's usually upgraded later Anyways. To Quote Tim the Tool Man Taylor. "More POWER! *Grunt grunt grunt*)
Timing belt is already scheduled (I Don't personally do the big things like that until I feel more comfortable with the engine). all that stuff is taken care of, I am referring to things I am needing to order
