Slow Starting
jd21
69
May 18, 2010
new tripoli, Pennsylvania
My 91 gsx is still really slow to start, it cranks fine just takes about 30 seconds to start no matter if its cold or warm. The timing is dead one, new plugs and wires, new coolant temp sensor, new battery, compression is 150-155 on all 4. I cant find any vaccum leaks i just replaced the injector seals, it has a new 255 in it i just cant figure this out pls help
Its a new fuel filter and stock fpr i need to get a pressure tester and check the fuel pressure
the battery is new, its not thats its cranking slowly it sounds really strong is just take about 30 seconds to start
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
