slipping clutch
doogle749
Mar 17, 2008
Delaware, Ohio
My TSI decided to start slipping in 3rd gear and up when the turbo whould kick in (3000 rpm +) so i replaced the clutch pressure plate and flywheel ect.. Fun week...
Now the same so.... i replaced the master and slave cylinder bled and adjusted still the same I may be a nube here but i have a few years under the hood so any tips traps ect whould be helpfull i searched the net/forums and still ???
Thanks
Bob
How many miles did you drive to break in the clutch. Usually if I do a quick pull on a new clutch It slips before 400 miles Maybe just take it easy for a few more hundred miles. Also if it's new did you grease the shaft and throw out bearing? Maybe just grease in there causing it to slip
