skunk2 adj cam gear install
So pretty much, I am removing the crank sensor.Then wiring the new 1g cas to the 2g crank sensor harness. The 1g cas yellow wire goes to the blue wire on the crank sensor harness. Red goes to red. Black goes to black. then the 4th wire on the 1g cas (white) goes to 1a on the chip inside the ecu. correct?
Or the 4th wire (white) can go to the blue wire one the 95 cam angle sensor harness
:thumb:
Will i have to switch pins on the ecu, and if so. What ones?
Do to switching the cas from the original right side of the intake cam, to the left side of the intake cam. The signal to the ecu reverses (inverts).
Making you have to invert the spark plug firing order, and the injector order
road race engineering sells a harness to connect the 1g cas to the 2g crank sensor and cam angle senor for cleaner look and solid connection
JNZ tuning sells a 1g cas pigtail if your capable of making your own harness.
After you connect the 1g cas harness. You have to do the following procedures.
using the 95-96 ecu diagram
put pin 1 in pin 14's slot
put pin 2 in pin 1's slot
put pin 15 in pin 2's slot
put pin 14 in pin 15's slot
this will invert the injectors to the right order.
you will also have to switch the two blue wires on the coil pack to invert the spark plugs firing order
Road Race Engineering sells a harness to connect the 1g cas to the 2g crank sensor and cam angle senor for cleaner look and solid connection.($50.00)
This is the best way to install a 1g cas in a 2g dsm. Because the car will idle smoother, and start better.
Quick note most people consider the black top cas better. Because it responds more efficient.
