Size of FP manifold race hardware?
Maxthepersonz
Supporting VIP
350
63
Feb 3, 2014
Madison, Wisconsin
Ffwd makes some nice bolts for the turbo. I bought the arp set and they were only in for like a year and I used high temp anti seize on install and I still needed to heat them and be real careful taking them out as they were stuck. I have a evo 3 16g and the turbine housing is made of a different alloy with higher nickel content, which seems to cause problems for others too. But it seems the ffwd bolts don't have that same issue from what I've read.
The rears are the OEM 1g/2g manifold to turbo bolts, and the fronts are Evo VIII/IX mani to turbo bolts, with two OEM turbo manifold conical washers between the bolts and the manifold. I just can't remember which way the washers are supposed to be facing, sorry.
edit: I just saw where you said that in your original post, if you go on STM's site, they have them listed in the OEM parts section for the respective model.
