should i use brake fluid or clutch fluid
xx1gdsm
34
Apr 25, 2010
lakeland, Florida
have a 1990 eagle talon tsi wonderin if i need clutch fluid or brake fluid..... it all the way at minimum
I put brake fluid in when my old altima was running low and it was all good from that point forward.
And that boost fluid sounds like my next upgrade. I'm going to get a full system to inject it like nos and run 5 seconds in the 1/4 mile! With 2,000 horsepower. In the rain. And reverse. :pray:
I use Ate SuperBlue Racing Brake Fluid in the brakes and clutch. It's blue so you know it's good.
"Boiling point minimum: 536 degrees F
Wet boiling point minimum: 388 degrees F"
