bob123131
- 457
- 2
- Dec 20, 2004
winona,
Minnesota
Just got back pricing from the machine shop on my build and its goin to cost about 240 for the machine work on my crank, and since im doin a full build just wondering if i shouldn't pick up a topline 100mm crank? My fear is with the fp1x cams, .5mm over valves and evo3 16g stroking the car might do more harm than good. If i stoke this would be the set up.
Mahle 8.5.1
eagle h beams
Evo 316g turbo
evo 3 intake mani
560cc denso
safc2
fp1x cams
stage 2 port and polished head
.5 mm oversized valves
3 angle valve job
I have all the parts, but pistons and crank so im ready to order, but will not be able to buy bigger turbo and cams for like two years. Is it worth it to stroke now or is my setup just to small for a stroker. I'm looking to have mid to high 12's on this setup 325-350 whp 20-24psi.
So ultimatley if its going to cost the same would you stroke or not with this setup for a street strip car.
Obviously i have more parts than above, but only ones i thought relavent to question.
Mahle 8.5.1
eagle h beams
Evo 316g turbo
evo 3 intake mani
560cc denso
safc2
fp1x cams
3 angle valve job
