- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- Evo 3 16g gt, evo3 gt mani, evo 8 injectors, evo 3 intake manifold, 1g throttle body, prothane motor mounts, afpr, Autometer boost, egt and air/fuel gauges, Greddy xl fmic with huge dent, evo 3 ported o2 housing, 3 inch stainless downpipe, 3 inch apexi n1 exhaust, injen intake, Custom short route piping Greddy type rS blow off valve and greddy turbo timer. Ngk plugs and wires. B&M short shifter with greddy shift knob & symbroski shift kit. Prothane motor mounts, fidenza ajustable cam gears, lightweight power steering pulley, afpr, denso 560cc.Turbo xs dual stage boost controller, walbro 255 hpl Fuel pump. Fidenza lightweight flywheel, Mishimoto radiator,1g cas conversion, emissions deletion,
- Mods-Engine
- mahle pistons, eagle rods, .5mm oversized stainless valves,5 angle valve job(infinite angle) , stage 1.5 port and polished head. .20 overbore, arp mains, acl bearings, balanced rotating assembly, FP1x cams and crower springs and retainers, arp head studs, cometic.
- Mods-EMS & Logging
- safc2 and aem uego wideband
- Mods-Drivetrain
- Act 2600pp and 6 puck sprung
- Mods-Handling
- Front strut bar and upper and lower rear strut bars. 17 inch rev rims,with rt615's.
- Parts Wishlist
- Qaife lsd.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Nitrous : No
Fuel Used : Pump gas
Tires : Drag Radials
- Dyno TQ
- 0.0 lb/ft
- Dyno Type
- Dyno Dynamics
- Dyno Shop Name
- lse
- Dyno Session Details
- Fuel Used : Pump gas
Turbo : evo 3 16g
Boost : 25
