shaft play on new turbo?
in and out or side to side?
Is this turbo installed yet?
You have to remember that the bearing run on a thin layer of oil. Once the oil drains down there is nothing to take up that gap.
When you say play, in what direction and how much.
Use a dial indicator, not guesstimation please.
I bought a used 16g and was wondering the same thing because it would move side to side a tiny bit and if I really put pressure on it it would move a little more. The turbo has 4,000 miles on it. I went to the local speed shop here and they had two brand new 16g's on display so I checked them and they felt exactly the same way mine did.
side to side is fine and doesnt really effect anything.
in and out means you're doomed.
