Setting My Timing?!
the only way to set your timing on a 2g is 1) with a 1g CAS (adjustable) 2) DSMlink
Wow, I learn something new everyday. I had no idea you guys were so "left out".
ok well i have another question for you guys......how about when uyou have your timing belt etc.... changed doest that through your base timing off and could result in loss of HP?? if this is the what could us 2g'ers do to set the base timing back to where it needs to be without buying dsmlink or a 1g cas,is there any other route to take???
