Setting a MBC
tamer
35
Jun 3, 2004
Kalamazoo, Michigan
Ok,
I know when I get a MBC it will tell me how to set it, but I'd like to know before since I'm still debating on whether or not I should get a Single or Dual MBC. If there is a way I can bypass a Single MBC to set it to the stock boost, and wire a switch to go to the MBC then I'll get a single. But if I need to have a Dual MBC to be able to set two and switch, then I'll just go for that..I think it's kinda pointless to get a dual if one will be set to stock boost, and the other will be set it a higher level. If I can do that with a single I'd rather save the money, and use it for something else...
Thanks,
Tamer
