1G Setting a Ford TPS
neuro_funk
57
Sep 8, 2012
san juan, Puerto Rico
Last year i converted my car to ecmlink v3 with sd, also installed a ford 76 mm throttle body with a ford tps, the problem is the tps is reading 0.90 volts when is fully closed, how can i set it up to read 0.63 volts?
i'm running a ford mustang tps, you sure you wired it correctly ? some of the wires changed colors and could be confusing depending which one you have...
here's how i soldered mine up to the oem connector so it would be plug/play with my harness:
nice nice, at least it's idling. now you can double-check base ignition timing and then adjust your idle where you want it to be. with cams/bigger intake manifold/ throttle body, piping, etc, you're bound to want to idle around 1krpm anyway, just depends where your setup is happy.
I did some mechanical tuning yesterday and now idles from 1018 to 1105rpm
    • Sdcryan1
