1G scat rod and wiseco piston combo
foxsdesignz
101
Jul 24, 2007
defuniak Springs, Florida
sorry about all the threads,, i am starting back on my AWD project,, ok,, i plan on scat rods with a stock crank,, with wiseco pistons,, my question is that they are 8.3.1com,, i shoulded need to do anything,, like i wont have any head clearance issue , if so can 9.0.1 pop right in,, with no worrys?
There is no way somebody could answer that question 100% correct. You need to know more about the the block, head, cams, and valve size. Most of the time you could just drop them in and if you can't tune well don't get a higher compression ratio it just makes it harder to tune and it has a smaller margin for error.
Steveb
