SBR G50 install with pictures
blcknspo0ln
DSM Wiseman
7,772
102
Jul 31, 2003
Central, New Jersey
I decided to go ahead and upgrade my evo 3 16G to a 50 trim and carefully chose out the slowboyracing G50 turbo. I have done a lot of business with SBR before so I decided to go to them for the setup. I spoke to MRL [Matt] over the phone and also Cragger when ordering my stuff. total came to 1000 shipped EVEN. this was for the turbo and EVERYTHING required to mount/install the turbo. new bolts/washers/gaskets/oil lines/etc.
The best part is that SBR helped me out with price matching the RS49T offered by AGP. Although the price wasn't as good, Matt hooked me up with a turbonetics compressor cover [already polished] at no extra charge. Would have been nice if they price matched entirely, but I'm not one to bi*** about price.
That said, it shipped pretty quickly [about 5 business days] and the turbo came to my house all nice and packaged neatly.
Now, here's exactly what went on with this particular install and I have pics too :)
-1G TB to 2G swap
-port matched 2G Intake Manifold
-50 trim install
-new stock foggers
-new crankpulley and belts
-tapped manifold runner for EGT, then plugged off for now
-rewired my existing 190 fuel pump
-slimline fan + use of stock wiring harness!
now here are some problems I ran across:
-Denting the water pipe; I had to do it since I didn't have the time to clock the turbo and remount the internal gate. the internal gate is bolted on with one of the comp. housing bolts.
-Since I couldn't clock the turbo, the outlet was pointing directly at the crossmember/motor mount. This was remedied by a 90* coupler, you can see that pretty clearly in the slimline fan pic above.
-I thought I had everything all gravy and ready to go, when my motor sounds like ROD KNOCK.. it literally sounded like the crank was scraping against something inside the block OMG . a guy from NJDSM came by and helped me out and we determined it was an old crank pulley. from the following pics.. you will see that it WAS the crank pulley. :notgood:
-The TB is still out of phase. I have no idleing problems, but my car will die if I let off throttle too quickly. This is due to the TPS. It reads ~4.5k/~1.5 instead of ~5k/.9K. take it from me and CHECK IT WHEN THE TB IS OFF THE CAR
I had a SBR G60-1 and loved it. The compressor housing outlet ran into the motor mount weird like that too. What I used was the stock upper intercooler pipe (connects to TB), and it was the perfect angle to get around the mount and go straight out to the passenger side.
I guess you didn't notice your own intake pipe, eh? :thumb:
*edit* nevermind you did, haha
Looks good. I really enjoyed my SBR G50 for the first 1700 miles, that is until it developed enough shaft play and needed to be rebuilt. ;) Oh and it was really great too for the next 900 miles, alot of fun. Too bad it needs rebuilt again... :thumb: Good Luck!
thanks for raining on my day :( Sorry you had bad luck, hopefully I won't have teh same. I see you have a PTE turbo now, did you make the switch?
LOL good eye, it's my sister's BABY BLUE scion. I have no idea when toyota is going to offer a turbo kit for the car, and I highly doubt that my sister is going to want a turbocharged tC.. seeing how my DSM is ROFL
take care of it and it wont happen, turbo time the shit out of it, I've had my car for 25k miles of its life, and beofr eI had it it had a small 16g on it, its still running strong with no shaft play at all due to the fact that im a mainteneace and turbotiming whore.
Nice little write up. Why the 1g to 2g tb swap? Hopefully the coupler holds up on that angle without leaking. The water pipe denting is normal for that turbo. Good luck with it.
1g TB is 60mm versus 2g TB which is 52mm.. more topend.
that POS fernco coupler has already melted.. a 90* replacement with t-bolts are coming in the mail hopefully today, I dont have any fear that it will seal properly.
is the 50 trim faster? I couldn't tell you that yet since I've only went WOT at 10 psi. Felt strong and the lag wasn't THAT bad.. I'll have feedback when I turn it up to 20 and log a little bit.
I have the utmost confidence that this 50 trim will kick my evo316g's ass :D
Going from a Evo 3 16g to a 50trim and keeping everything else the same(boost level etc.) I gained 4/10ths and 2mph in the quater, I also had a big boost leak with the 50 trim so I am sure the gain is even bigger.
