Say something about the person above you. Pt II
Needs to help motivate EDM
One step at a time man, you can't look at the big picture or you'll get overwhelmed. Just focus on the end product and the one step you're currently on. It helps me, because I get overwhelmed easily.
Should expand on this "chip" he has.
Bud, what I mean by dish is the combustion chamber volume in the head, like the bowl kinda resessed thing in the head with the valves... kinda hard to put in text, but I think you'll get the idea. Anyway, the smaller it is, the higher the compression ratio.
Knows than that would mean the 2g dish is smaller..But the pistons are also higher compression that 1g's..So I'm not sure on which combustion chamber is going to be bigger..
And my1gdsm, burns custon chips...Which might help you, but you have link don't you?
Knows an old sock and this stuff called brasso..Takes about 30 seconds a headlight..But needs to be done every couple months..
Or toothpaste, but that takes alot more elbow grease..
Is off his pop addiction.
Knows that's impressive, good job. :thumb:
Is right and wrong. I don't need a tune right now, but next year will need a complete re-tune.
Needs to get that car together and sell that van!
Knows this is what my car should look like but it's took all apart.:cry:
Needs to tell me why it isn't done yet.
Should know its because tonight will probably be the last time I'll drive the car till spring.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
