Saturn alternator wireing promplem.
jdigitty
155
Aug 1, 2009
lakewood, Washington
Ok well I just finished my build for the most part. I still need a few more thing i.e ecm link gauges so I put stock injectors back in. So I can start the car and put in on the trailer.
Here where my problem is I go to wire the alternator with the write up in the tech section but the battery was almost dead. So I put it on the charger then hook it up then I had to go so when I came back I hear a whining noise from the alternator. I unplugged it then get in the car turn the key and battery was dead radio came on and seat belt worked. I came on here looked it up found out about s wire. I went and bought the plug.
I think I wired it up right L wire to mitsu black and white wire S wire to distro block.
charge the battery again and hooked up the jumper cables to it also to be safe. When I turned the I hear the clicks like i should but the seat belt isn't working and the radio didn't come on also I turn the headlight on and nothing. I checked the fuses and the radio fuse under the dash has power. I didn't try to start it. I'm lost? I have a week to get thing running.
Any help is appreciated.
Thanks
Update- I got the car started for the first time after the build. It runs fine but I cant figure out why the seat belts radio and lights don't work. The seat belt light does blink when running.
