SAFC with 16g, 650's, and 3g maf
Chaotic94
177
3
Oct 5, 2013
West Plains, Missouri
So I've read a little here and there about what I'm about to ask but haven't really got a answer. I have the following stuff that I can use on my car.
MHI Small 16g
2.5 turbo back exhaust
650cc Injectors
3g maf
Safc
Walbro 255
Here's my question. I want to run the 16g on factory wg pressure. And from what I've read, I will need very little tuning if I run the 650's with the 3g maf. So what I need to know is will I be safe with the 16g on stock wg pressure, 3g maf, and 650's with the safc? Just until I can get a for to run the Walbro 255 and dsmlink to do some real tuning to turn up the boost.
Thanks for the insight. I know it's not recommended to tune without a logger but I don't want to spend money on a logger when I'm trying to save for link. Will I be okay just using a wideband to dial in my afr without a logger? Like I said before, planning on stock wg pressure for now until I get link. So I'm just curious how much I should worry about knock and whatnot as long as my afr is dialed in with the safc..
