safc tuning
V8KLR
81
Nov 22, 2008
Johnson City, Tennessee
I know that the SAFC is RPM based instead of load based. I just got a water injection kit for my car and i'm going to run 93+water/alcohol mix at 15PSI (i'm currently running 9-10 PSI with no knock on 93). Will I have to tune the SAFC richer for more boost or will the extra air the MAF see's plus the water injection be enough to keep knock down?
Typically the WI will allow you to lean out your AFR's. Many guys end up running 12.0:1-12.5:1 at WOT with good results. But as always you need to monitor things using the datalogger and preferably a wideband as there are lots of variables which will affect your final tune.
