SAFC Tuning
sYnOnYx
270
Jan 24, 2005
Las Vegas, Nevada
ok , so a month back i hacked my MAF , and after that i ran hella rich and lost about 100mi per tank of gas, and the car didnt feel as strong , a local guy suggested an safc to lean it back to normal, i tell you what with the settings the previous guy had in it (came from a 4g63 car) the car ran awesome........ and no running rich....no sucking gas like usual
but then i dont know what the hell happend , and the settings got reset......( i just did this mod last night) and bam! back to sucking!
my mods are : exhaust , maf hack , boost controller on 15psi (autometer gauge)
so can anyone suggest what i can do to get back to where i was ???
if it makes any diffrence i hardly ever get on it , unless its nice and cool out..........
maybe 3-4 times an entire tank , and only for maybe 15 seconds.
too late for that one now isnt it ?? your post added nothing useful to the topic...
im running -10% across the board on low throttle , and 0 on the high side.........
seems to be running like it was before.
yes it does, it implies you should unhack [i.e., get a new one] your MAF.
if you're that adamant about getting spood fed, just get a logger and do a couple WOT runs. adjust accordingly.
First thing is I hope you only hacked the side honeycombs and not the main one cause if you did your screwd anyway. Second is you have it backwords I think. When you hack your MAF you don't run richer you run leaner because you are now flowing more air with the same fuel trims.
