SAFC II previous settings
eclipsemustang
110
Nov 15, 2005
suburbs, Minnesota
I installed an SAFC II last fall before i stored my car and this winter i installed an A/F gauge, and i know that A/F gauges arent the most accurate gauge but i know it sohuld estimate close to what the car is running. So ive driven the car a few times since the installation of the gauge and when the car is idling the light says the car is running so lean the light goes below the gauge's lean lights, but im wondering since i bought the SAFC II used could some settings be saved? or is this just something with the gauge?
The low trim bounces around alot, do you have a logger to see ## low trim? Settings are saved in the afc even after the battery is disconnected from it. Have you tryed adding with the afc to see if the A/F will respond to it?
