safc settings
92_laser
37
Dec 7, 2005
Sandpoint, Idaho
I just installed my safc and I was wondering what settings I should start out with. If anyone can help or can point me in the right direction....
Thanks
K_Hill said:
This is a very helpful link..
http://www.roadraceengineering.com/newafc.htm
and another..
http://www.dsmtuners.com/forums/showthread.php?t=103469
Download this.. http://users.wpi.edu/~ktarry/dsmtech/DSM_Tuning_Sheet_v2.1.xls This will help you get your safc tuned in so you can start tuning.. Before you start tuning you will need a DATALOGGER. If you don't have a datalogger put all your corrections at 0% acroos the rpm range.
I'm new to tuning as well, why would you put 0% across the board?
Just to help clarify, an AFC will help you ad or subtract a certain percentage of fuel from what the engine would normally get. A setting of +10% would give 10% more fuel and likewise a setting of -10% would give 10% less fuel. People that get large injectors or that start running more boost need to add and subtract fuel from different points. K Hill suggested you put 0% across the board because everything is stock. The AFC will not add or subtract fuel from anywhere because it does not need too. The links he provided are a good place to start research and yes, you no doubt need a logging device to start anything. Good luck.
Thanks for the replies but now I have another problem. The safc wont turn on.... Is there an on switch? I followed the instructions on vfaq.com to the "T". The only difference was the ground wire on my ecu did not have orange bands but I went with the corresponding plug.... Please help
It was the plug inside the safc... what settings should I start my tuning with? +/-? Th-points lo and high?
Thanks
Don't go overboard with throwing settings up and down. Every single car is different and overtime the wrong settings could be unhealty for your car. I would leave it alone until I get it tuned by someone who knows what their doing. Make sure you intialize it before you start playing with it.
K_Hill said:
0% correction across the rpm range is stock setting.. Don't start tuning unless you have a datalogging device!!
in setting 0% correction across the board you may encounter a few things. if you have 550cc, 650cc, or 750cc injectors, you obviously are going to be running that cc of injector and therefore not runnig "stock", a logger in necc. or get a wideband o2, plx has the m-300 for something like 275 or a little more. 0% will not necc. be okay, your car still may feel sluggish in that setting. so good luck and hopefully this helps too.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
