s16g w/14b exhaust housing
coryd
73
Apr 10, 2005
sioux falls, South Dakota
i just bought a s16g from a buddy who totaled his car awhile back. the exhaust housing on the 16g is badly cracked around the wga. i have an extra 14b laying around with good ported exhaust housing. i was thinking about putting the 14b exhaust housing on the 16g. so in theory wouldnt i build boost faster then a normal 16g because im pushing same amount of air into a small housing in turn it would cause the wheel to spin faster and build boost quiker??
what do u guys think?
well 14b,s16g,b16g and evo 16g all have the same exhaust housing the tdo5h but puttin the ported one on will be a good upgrade itll help will spool up, and boost creep
They do not use the same turbine housing. The 14b uses a 6cm housing, the small and big 16g's use a 7cm housing, and the evo 3 16g uses a slightly different 7cm housing. You can use a 6cm housing with a small 16g because it uses the same turbine wheel.
I use a 14b housing on my evo 3 because all the mani to turbo bolts snapped off cause of the ### metal gasket. I havent had a problem with it yet and it actually spools quicker so.....then again i DO know the drawbacks to a smaller turbine housing.
ya, im hoppen for a quiker spool up because its mainly for streat use, once i get it all done i will let u guys know how it goes
I hope you dont mind running 18-20psi minimum. I put a small 16G into a stock turbine housing and it would not hold any less than 19psi. So I set it to 19psi and it holds solid till redline. Just make sure you are prepped for 19psi all the time.
Later
Sorry for bringing this thread back to life, but I got a question. Would using the 14b exhaust housing onto a s16g be an upgrade? What is the tradeoff for using a smaller, 6cm exhausing?
I think with a smaller housing you would get a little less fuel economy, heat dissapation would be alittle less efficient, and you may loose a little top end. Of course, this is based on my thinking logic. The differences will probably be so small you wouldn't notice. I definately wouldn't call it an upgrade by any means
I figured the top end would suffer.
Great mod for guys running automatics. Makes launching and driveability so much better. Difference in spoolup is about 400-500 rpm or so. I got full boost by 3000 rpm on a 6cm housing vs. 3400 rpm on a 7cm. I had a 10* clip on the s16g/TD05 wheel so that helped the topend but hurt spoolup a bit.
Its definitely much quicker spooling than a T28 for instance. Based on my butt dyno I'd have to say a loss of maybe 15 h.p. on the topend.
well, after some time testing it i ran into problems with boost creep. it would spike up like 2-3 pounds but would hit full boots about 750 rpms sooner. and this was with a very nicely ported 6cm housing. so i wouldnt recommend it
Your topend will be horrible. I ran my 18g with a 6cm housing and it was actually slower at the track than my 14b was at the same boost. The problem was the motor was outflowing the turbo at anything over 6 grand causing boost to drop to 15 pounds. This caused the car to run pig rich up top.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
