Rust problem and my solution
sschambers
143
9
Sep 26, 2007
Hermitage, Pennsylvania
So I've only ever had to patch 2 small spots on my 97 GS-T since I've had it. Even though it came from New York, it's in excellent shape.
I jacked up the rear last night around 9 to fix my exhaust rattle. Well I fixed the rattle, but while under the car I was peeking around and found a spot that looked like it might be rusted...
I took my fist and GENTLY just tapped upwards, and the next thing I know my hand is inside my hatch. So I got a small mallett and tapped all the bad metal away. Well it wasn't just a little bit of bad metal...It was a lot of bit. Before I knew it, I had a hole big enough that I could stick my head through. I realized what had caused this problem.
About 6 months after I got my car I realized the drain pipe for the passenger side hatch was clogged up. I'm thinking that the whole time it was clogged it, water had accumulated in the small area behind the plastic hatch panel (passenger side panel). Causing it to rust out. Because my driver's side rear is in perfect shape.
After hours and hours....and hours of grinding, sanding, cleaning and forming a new piece to fit from scrap sheet metal, I finally finished it. Now I have no more worries about rust. The welds are strong, the patch is durable and I feel confident that this piece won't rust again.
The piece of scrap metal that I used was actually a piece of thin steel from an old tool box. It seemed to be a tad thicker than what originally was in there. Here's some pics...
BTW: it was hell trying to weld right next to the gas filler tube...
Top view of rust hole
Bottom view
Another bottom view
Top view with patch welded in
Passenger view w/o wheel and undercoat applied
Bottom view, undercoat applied. Had to drill a hole for the drain hose.
Top view, undercoat applied
Bottom view, hoses re-installed
Same as previous, different angle
The damage...
Just goes to show, a little rust won't ever keep her off the road. I don't care if the entire body rots away, I'll find a way to fabricate it back to operable shape :D
Yeah those shitty drains get clogged a lot. I have some rust as well but not as bad as yours. I'm trying to think up ways to prevent it. Might have to resort bedlining the whole trunk.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
